Question about Transformer Terminology
budder8818
Junior Member level 3
New Jersey, USA
I have a question about the wording of transformer probelms. See diagram
So the question says:
A 1 phase 3kVA 240/120V 60HZ transformer has a feeder impedance .75+1.17j.
Determine the voltage regulation when the transfomer is supplying full load at 110V and .9 leading power factor.
My questions:
1. Ok, so what are they talking about when they say "supplying full load" I am assuming the load is at the low voltage terminal?
2. When they say "at 110V" what are they talking about? Where on the circuit diagram is the 110V. In addition, is that 110V rms, in other words, is that 110V at 0 degrees or is there some unknown phase angle?
Thank you I'd really apreciate some help.
:grin:
1. Load (full load -approx. 3kW) is concted to the secondary winding, marked as EL ..
2. 110V is again the secondary winding, and it should be RMS ..
IanP
Ok so 110volts across the secondary winding at 0 degrees? and how did you get 3kW for full load?
for 110Vrms => sin has 155Vpp at 90deg, cos has 155Vpp at 0deg .. you can "play" with degs as much as you like ..
This is 3kVA transformer so full (resistive) load will be 3kW ..
its not fully resistive though. The power factor is not 1. Right? Isn't there some Vars to the load. So I could use relation S=VI* to find I. Where S is the load power and V is the power across the load.
Thanks for staying with this.
