question about spi situation in mp3
ghoola
Member level 2
Member level 2
india
what is spi_low and spi_high used for?
I guess you are referring to the chip select ie. the way the SPI slave device decides to connect with the master device. It could connect at the active high or at the active low of the strobe CS or SS (chip select/slave select)
Reactions: pdude
    pdude
you know I want to know the main work that this register do?
