Hi all,
I'm sorry to ask...
but I hope there's someone in this forum who have experience in designing slot antenna. OK, as mentioned, I'm trying to design the slot antenna which feed by microstrip line.
The question are:
- First for the feed line, from the reference I only got impression that the width of the microtsrip line, contribute to the impedance. but what about its length? how can I figure it? I mean, what is the length value I should chose/use. because there's no explanation regarding it.
"there is no fix length for microstrip line. you should design it to the actual length that you are going to use. But then, during design, you have to look at the smith chart. you will notice that as you lengthen the m/s line, the smith chart plot will just circulate accordingly. So the best bet is to simulate to the length you are going to use or where you are going to mount your connector to it. Also, as you lengthen your m/s line, you will notice an increase in your inductance."
- I'm simulating using IE3D, so I made slot in the infinite ground plane, and then I add the microstrip line for the feed on top of the dielectric. And the I add edge-feed on it. Is that what I'm done is correct. If not please assist me.
"For a start, simulating in infinite ground plane is ok. You need to at least get the design you wanted in n ideal situation first to get a hang of how the slot antenna will match to your port. With you start to define a finite ground plane, the result will shift a litte, but since you already know the trend of the shift, you should be able to tune it back. So no worries. "
- At first when I'm simulating I use infinite ground plane, but of course it's inpractical, so if I want to use finite ground plane. How I can determine its dimension? Is there any "guidance" on it.
"1/2 wavelength is the bare minimum i would say, don't go less than that. You can try to reduce your gnd plane size in steps to see the effect of it. Once it goes beyond the point where you cant tune your slot back to the operating freq, thats more or less your limit."
Thank you for your time and help.
Regards,
