Question about PT correlation in MAGMA
xworld2008
Full Member level 4
Full Member level 4
about PT correlation?
who use MAGMA to do P&R? when after synthesis with DC and before P&R with MAGMA, you must translate SDC to MTCL and check SDC and Mtcl file match or mismatch.
First, you use PrimeTime to generate endpoint report.Then You compare endpoint report file in MAGMA,if mismatch,you must revise MTCL to match SDC,this is called as PT correlation.
who have experience about it?who can tell me where these mismatches will happen?
Re: about PT correlation?
Moved to correct forum.
