Manchested
Member level 5
Hi all,
Does anyone know if connecting a resistor in parallel with a pot using A and B terminals, will it be able to vary from 1ohm to total parallel resistance?
---------- Post added at 22:27 ---------- Previous post was at 21:42 ----------
for a linear dual gang pot, say the total parallel resistance of the top resistor is 100ohm and the bottom one is 200ohm.
When the top one is tweaked to 30ohms, will the bottom one be 60 ohms?
