andover
I got one question about the requirement of having small output impedance of the output amplifier to drive a low load resistor. I understand if we simply model the output amplifier as a voltage source in series with the output impedance(thevenin), so that most of the voltage signal is on the load, but if we use a current source in parallel with a resistor as the model(norton), we are expecting a large output resistance, so that most of the current is on the load, right?
So my question is why low output impedance is required for the output amplifier.
Thanks
Thanks
