jmx66
Member level 5
Hi all,
I plan to use an igbt module , in order to replace 6 discrete igbt burnt, on my bldc card.
Power 1500 W V bus: 340 V Rated current 4,5 A
Which component is best suited for the job:
Also i'd like to know if resistor between T1 and T2, has same function than R1, on a "conventional" design.
See draft joined.
Thanks a lot.
jm
See draft joined.
Thanks a lot.
jm
