Question about graph of toggle output timer
banh
Advanced Member level 1
toggle output
i have a 16-bit timer that toggles output when there's a compare match.
i change the compare value and note down the corresponding frequency at the toggled output.
from those data, i plotted a graph compare-values vs frequencies..
the graph is not linear... is it supposed to be linear?
Re: toggle output timer
It has to be nonlinear! Plot a graph of compare-values VS period of toggle it will be
linear.
linear.
sorry, what do you say? linear or nonlinear?
my plotted graph is nonlinear, and i think it should be linear.
my chart looks like this.. (vertical axis is frequency)
Hi ur chart is nonlinear its correct This is what ur are suppose to get theorotically.
If you plot period Vs compare value you will get linear plot!
oh yeh you are rite...stupid i am... just dun realize the fundamental stuff..
