fantaci
Member level 3
In every textbook, the feedback stability is described as one input singal, one output and the feedback signal.
But how to analize the system which has no input singal, such as tieing the output directly with input? For example, a simple LDO, if the input voltage does not change and could be viewed as vitual ground in small signal analysis. If I have no input signal, how could I analyze the stability when some disturbance happens?
