danda821
Full Member level 2
ie3d edge meshing
When I use IE3D, I found when I consider all the metal thickness (3D metal) and mesh it. There is not much difference in the total cell number with or without edge cell. So can I say for 3D metal meshing we do not need to worry about the edge cell size?
For metal growing, there are "1st Degree Compensaton" and "2nd Degree Compensatoin with Pre-Processing"? which one is more accurate?
what is the difference between Contemporary and Classic Meshing scheme? Which one is better?
Sometime when I mesh the structure, I got some warning message "between ... and ... forced meshing cell size is smaller than minimum cell size". Can I ignore it?
Thank you.
danda
Thank you.
danda
