Question about counter (disconnecting clock)
Haytham-Sief
Member level 2
Member level 2
Alexandria, Egypt
Question about counters
Plzz everybody if any one can tell me if the clock provided to a counter is disconnected what will be the output of the counter ? Will it be the last output (i.e. latched) or it will be reseted ??
Thnx very much
Re: Question about counters
Ofcourse, it depends to the freezing time of the clock, if it happens in low to high or high to low transition edge, the value could be unknown, but if the clock is freezed during high or low level, the counter keeps its value.
Regards
If you use cmos type ic.Must be pull down res. for clock input.If you dont have counter not exactly last count state.
The counter will hold the last count. If the input waveform stays low or high the counter will not increment the count. The thing to look out for is how you disrupt the input signal. If the counter input is left floating, noise will produce more counts.
