jianhuachews
Member level 2
![Member level 2](/styles/images/ranks/dlevel2.gif)
hi guys.. I have 3 separate programs now and they are a seven segment decoder, a 4bit up down counter and a frequency divider.
I need to combine these merge these 3 programs using configuration specification however i'm very lost when i tried doing it. I read up online sources but i could not understand, still.
This is what i tried doing, ok but i very sure it's wrong. And there's a fatal that states "unexpected signal:11"
Re: Im having trouble with the part in red!!
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
use IEEE.numeric_std.all;
entity counter_top is port (
clear, updown, load, enable, clk: in std_logic;
data_in: in std_logic_vector(3 downto 0);
d1: out std_logic_vector (6 downto 0);
g1, g2, g3, g4: out std_logic
end;
architecture behavior of counter_top is
component seg7 port (
I : in std_logic_vector(3 downto 0);
seg : out std_logic_vector(6 downto 0)
end component;
component counter port (
en,clk, clr, up_down, ld : in std_logic;
din : in std_logic_vector(3 downto 0);
Q : out std_logic_vector(3 downto 0)
end component;
component freqdiv port (
input_clk: in std_logic;
output_clk: out std_logic
end component;
[COLOR="#FF0000"]signal clkdiv_out: std_logic;
signal seg_out: std_logic_vector(6 downto 0);[/COLOR]
begin
g1 <= '0';
g2 <= '1';
g3 <= '1';
g4 <= '1';
[COLOR="#FF0000"]I1: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(3)=>data_in(3), input_clk=>clk, clr=>clear, output_clk=>clk, Q(3)=>I(3), seg=>seg(6));
I2: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(2)=>data_in(2), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(2) =>I(2), seg=>seg(5));
I3: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(1)=>data_in(1), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(1) =>I(1), seg=>seg(4));
I4: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(0)=>data_in(0), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(0) =>I(0), seg=>seg(3));
I5: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(0)=>data_in(0), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(0) =>I(0), seg=>seg(2));
I6: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(0)=>data_in(0), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(0)=>I(0), seg=>seg(1));
I6: seg7 port map (ld=>load, en=>enable, up_down=>updown, din(0)=>data_in(0), input_clk=>clk, clr=>clear, clk=>clkdiv_out, Q(0)=>I(0), seg=>seg(0));
d1<=seg(0);
[/COLOR]
end behavior;
configuration cc of counter_top is
for behavior
[COLOR="#FF0000"]for all: seg7 use entity work.seg7(behavior);[/COLOR]
end for;
end for;
end cc;
