question about APB frequency
rakesh_reddy
Junior Member level 2
Hi.,
1) Can someone tell me what could be the maximum clock frequency of apb bus..?
2) Like frequency ranges of apb bus at which it can work.?
Thanks,
Rakesh.
thank you..! it means that we can use this bus even for high frequency applications too.!!??
You can, but throughput isn't very good, as APB takes at least two cycles per transaction. Better to use AHB.
hi imbichie ,
thank you for your response..,
can you gimme little info about how to initiate MakeUnique transaction using ace/axi4 transactions. I mean which signal is used for initiating that transaction..?
