Question about AC Coupling
kiat
Newbie level 6
Newbie level 6
ac coupling
hi guys, i have some doubts on ac coupling and i hope someone can help me. with ref to the circuit and the following details,
vcc=1.8v
input signal is a pulse with high=0.2 and low=0v
wat would be the signal after passing through the capacitor?
Re: AC Coupling
and your frequency/pulse period is?
AC Coupling
freq is 10MHz, so my pulse period would be 0.1us
Re: AC Coupling
The time constant of the RC is 5 us and your signal period is 2% of this so there will be little pulse distortion. The average signal on the right is the power supply voltage. The AC component of the input gets put across the capacitor so you will get on the transistor side the same shaped waveform but with the high Vcc+0.1 and the low Vcc-0.1.
AC Coupling
hi flatulent, tat's wat i tot too.... the waveform should be at (vcc+0.1) as high and (vcc-0.1) as low... but instead i got (vcc+0.2) as high and vcc as low... any explanation for that?
Re: AC Coupling
The circuit is linear so superposition holds. There is an AC and a DC component. On the right the DC component is the power supply through the resistor with no current flowing. The AC component gets across the capacitor.
This is the verbal solution. You can also do the math.
AC Coupling
so u think the solution should be vcc+0.1 and vcc-0.1?
Re: AC Coupling
Yes, all of this assuming that the FET does not have protection diodes on the gate and the gate capacitance is very small compared to the 100 nF. Also that the input pulse is periodic (you mention a repetition rate of 10 MHz.) A one time pulse would get you the vcc, vcc+0.2 situation.
AC Coupling
Hi Guys,
I think it should be vcc+0.2 and vcc for the high and low value. since after the positive pulse, the AC part will stay at about 0.2 (since 0.1u <<5u) and when the negative pulse comes, the AC part goes to 0.
AC Coupling
hi, can u elaborate further? even if i put my pulse as high 0.1v and low -0.1v... the pulse after the cap is still vcc+0.2 and vcc...
AC Coupling
When there are 0.2v difference between the high and low level of pulse (no matter from 0 to 0.2 or from -0.1 - 0.1), the right side of Cap will go up as high as 0.2V and then start to discharge, however, since the time constant of the RC high-pass filter is much larger than signal's period, the voltage will not go down a lot (or it approximately stay at 0.2V), and then a negative pulse will bring it to 0V.....
Hope it is clear enough!
