[Questa] How to find multiple drivers using QuestaSim?
ivlsi
Advanced Member level 3
Hi All,
Thank you!
well used the "-check_synthesis" with vlog/vcom, and that's add checks like this.
Reactions: ivlsi
    ivlsi
Thanks!
Probably you know why I cannot add signals from Source Window to Waves... What's the best way to do so? When I right Click on a signal in the Source Window, all the options under the 'Add' submenu (including an option Add->ToWave) are in grey color... Why? Drag & drop also dosn't work... So, how to enable adding the signals from Source window to Waves?
Thank you!
Could you please provide the full command for combination of vlog/vcom and "-check_synthesis" switch and others? Thank you!
vlog -help :)
