piyushpandey
Member level 4
Hello guys
I have two questions one is regarding the TL431 and the other is regarding the OPAMP .
My first question is that I want to get the refrence voltage of 2.5 volts from the TL431 but in the datasheet it is given that it can be regulated to any value from 2.6 to 36 V so can't I get the 2.5 V and the minimum regulated voltage which I can have is of 2.6 V
I am using these two schematics so please tell me that which one will provide the 2.5 or 2.6 refrence voltage.
the pics are here:
First one which I think will not serve the purpose as it is ground. and second one will provide the refrence voltage.
I just want to be sure that what I am thinking is correct by asking you expert people.
Now second question is that I want to measure the sinusoidal current coming to my home through an ammeter I am designing and for that I am using the cheap shunt , I know that my purpose can be solved very easily by the use of the current transformer but I am opting for the shunt because of two reasons first it is cheap and second I want to learn how shunt works.
So since the resistance of the shunt is very less approximately .01 ohm so the voltage drop for a 5 A of sinusoidal current would be very low in the miliamp range and therefore I am using the OPAMP for it .
But what I realised that the opamp will no be able to read the negative value of the input voltage signal as the voltage range to the OPAMP is from V+ = 5v to V- = 0V so it will measure the positive value but not the negative value , so what I have to do is that I have to give it a bias and therefore I am providing it the bias of above mentioned 2.5 V at the input signal .
So am I doing right or something elese has to be done or the input signal should be given without any bias to the OPAMP.
the schematic is as follows:
So I want to know that my circuit is right now the first one and in the second one I have put the bias at the signal input end of the opamp i.e. at the CT_o/p end of the circuit.
So please tell me if I have added the bias correctly and also I must tell there is no other power supply and the opamp has only the 0 to 5 V of the power supply and also the opamp is operating in the non-inverting mode.
Thanks
Piyush Pandey
the pics are here:
Thanks
Piyush Pandey
