FreshmanNewbie
Advanced Member level 1
There's this MOSFET (https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/414/SH8K5.pdf)
The gate threshold range for this MOSFET is given as 1V to 2.5V from the table (but from the table I see this value is for a drain current of only 1mA).
My question is, I want to get a drive current of 1A. In that case, What should be the maximum allowable gate-source threshold voltage I can give?
Seeing the graph below, Gate-Source voltage vs Drain current, the maximum gate-source voltage that is shown is 3V.
So my question is:
1. What is the maximum gate-source voltage that I can give to get a drain current of 1A?
2. What if I give 10V as gate-source voltage? - I know that I won't damage the MOSFET as the maximum gate-source voltage that is mentioned in the datasheet is 20V. So, what would happen if I give 10V as Vgs?
So my question is:
