arbalez
Member level 5
![Member level 5](/styles/images/ranks/dlevel5.gif)
After doing full compilation of my design, i got the following warning messages. the documentation does not explain in detail on how to solve the problem. i do hope that somebody who had experienced this before could advice me.
in Quartus docs, they said something about programmable invert but does explain in detail on how to use it. this is a problem of using inverter to provide oscillated signal.
why cannot?
i don't understand this message. every of my entity declaration and processes (in architecture) has their own asynchronous reset.
again. inverted clock?
how to define input clock ports?
how to implement this?
some other questions. what is the technique usually used to reduce fan-out by coding (VHDL)? some of the components synthesized has fan-out more than its limit (50).
thanks in advace.
Critical : Design Assistant Warning: Logic cell should not be used to generate inverted clock.
Critical : Design Assistant Warning: Clock signal should not be a global signal.
Critical : Design Assistant Warning: Combinational logic used as reset signal should be synchronized.
Warning: Design Assistant Warning: Design should not contain ripple clock structures.
Warning: Design Assistant Warning: Clock signal source should drive only input clock ports.
Warning: Design Assistant Warning: External reset should be synchronized using two cascaded registers.
thanks in advace.
