Quantum Mechanics problem.....
nikhilsigma
Full Member level 2
Full Member level 2
Delhi, India
following is a question from Neaman's "Semiconductor Physics and Devices"..
An electron has a kinetic energy of 20meV. Determine the de Broglie wavelength...??
please explain how to solve this.....
λ = h / p
= (6.6 * 10 exp -34) / (5.91 * 10 exp -24) = 1.116 * 10 exp -10 m
= 0.112nm
therefore de borglie wave length of the electron is 0.112nm
First of all....how you found the momentum "p" as kinetic energy is given ??
as i know kinetic energy is ½(mv²), and p= mv
BUT v is not given....!!
so this is a problem....... :sad:
Also in book the Answer is : p=7.64x10exp(-26) kgm/s , λ= 86.7 x 10exp(-10) m
h is plancks constant h= 6.6* 10exp -34 Joules sec
try this... the momentum can be determined (non relativistically) as p = sqrt(2*KE*mo) where KE is kinetic energy in Joules (or eV) and mo is the rest mass in kg (or eV/c^2) If using eV/c^2 for your units of mass, it is easier to use the relation p * c = sqrt(2*KE*mo*c^2) Once you know the momentum, getting to the DeBroglie wavelength should be straighforward ... lambda = h / p where h is Planks constant (6.63e-34 Joule*sec)
have Fun
good one dude.....I also managed to get that.....
Anyways thanks for the Solution..... ;-)
