Quadcopter or Drone designings
rajaram04
Advanced Member level 3
earth
Hi all
Here i want to know about the major facts by which a quadcopter works or say liftup ?
Is it
motor speed ?
propeller design ?
battery power ?
or
what ??
thanks
You need power,propeller design to produce drag and speed
so how we produce such design ? in what way ?
It is important to use a lightweight Li-Po battery.
mm so from where i could purchase such LiPo battery ?
i mean any trusted site ???
If you are a a beginner and if you are too much confused, then I would like to share a link http://blog.oscarliang.net/build-a-quadcopter-beginners-tutorial-1/
Because it is not very easy to explain in few lines, it is complicated.
Just powering the 4 motors with same voltage/pwm doesn't means that it will lift up, it can flip and strike on the floor and will endup with damage. You need to use an IMU based control system to ensure the stability. Details regarding the battery, circuitry, algorithms etc will be there in the attached link. Please check it out.
My local hobby store sells regular model helicopters, quadcopters, airplanes and cars. All are radio controlled and most have accellerometers and gyroscopes built-in for good stability. All the flying models are powered from powerful but lightweight inexpensive Li-po rechargeable batteries designed in the USA. Cheap Chinese poor quality Li-Po batteries are available online from ebay and Hobbyking.
My local hobby store sells and I buy most products from the American company www.horizonhobby.com .
