qu@rtus II questions(outputs)
cages
Junior Member level 1
Is there a way to set all output pin in a design to low when powered up
until the pin is driven or do you have to design this function into your code.
i just flashed my first verilog design on a dev board but the Leds keep flashing randomly until reset is pressed wich is supposed to start the code.
