Qt signals "and" logic
emresel
Full Member level 5
Full Member level 5
Turkiye
Hi;
I am not sure if much people in here interesting Qt.
It is based on signals and slots. I am also new on that...
What i want to do is to trigger a slot when two signals are emitted.
Something "if signal1 and signal2 is emitted then trigger slot".
I couldn't figure out how to do so.
Basically connecting two signals to a slot doesn't help, because in this case "when signal1 or signal2 emitted, then slot is executed".
It is "or" logic of signals.
Somehow i need "and" logic.
Any idea?
Kind regards
Is your signal a simple On/Off change in volt level? Then it should be easy to distinguish by diode logic.
Did you find you cannot use diode-resistor 'AND' circuits, or diode-transistor type?
Or maybe your signals is pulsed DC, or AC? Then you have to convert it to something which is easy to detect. Then you feed it to the 'AND' circuit.
Are you connecting them by using Qsignalmapper?
Hi;
I directly connect two signals to slot with the standard connect syntax.
As i checked Qsignalmapper, it helps to map multiple signals to single slot but i couldn't figure out if it is possible "and"ing signals or give any order to signals with signalmapper.
Is it possible?
Could you please give me any related example?
Thanks
You could set flags there, and make the AND logic externaly, at the main loop.
