I have IC614 installed. DRC and LVS are running fine but there is a problem facing during QRC run. Before the details of the error, please have a look at the configuration of my current setup:
Platform: Cent OS 5.8 [64 bit]
Installed Cadence Products: IUS08.20.017, IC06.14.512, MMSIM10.11.218, ASSURA4.12-614
Technology: UMC_180_ANALOG [64bit] (1.8-3.3V, Mixed-Mode, 1Poly6Metal Process)
I have configured .cdslib. assura_tech.lib, .cdsinit and .bashrc files to have my cadence installation running fine.
To verify the whole setup, I just created a simple inverter (in Virtuoso Schematic Editor XL), did a schematic-level simulation (in Analog Design Environment XL), did its layout (in Virtuoso Layout Suite XL), did DRC and LVS (in ASSURA).
Up to this point there was no problem.
After this when I tried to perform a QRC run, it failed. The error is:
Cadence Extraction QRC - 64-bit Parasitic Extractor - Version 10.1.2-s124
Tue Aug 23 16:37:08 PDT 2011
Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
/software/cadence/ASSURA/tools/assura/bin/rcxToDfII /research/samiran/umc18a64bOA//myInverter/__qrc.rcx_cmd -t -f /research/samiran/umc18a64bOA/myInverter/extview.tmp -w /research/samiran/umc18a64bOA/myInverter -cdslib /research/samiran/umc18a64bOA/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.17s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.500.10 08/05/2011 12:09 (sjfql211) $
sub-version 4.1_USR2_HF9, integ signature 2011-08-04-1344
run on jupiter from /software/cadence/ASSURA/tools.lnx86/assura/bin/64bit/rcxToDfII on Fri Jun 8 17:03:51 2012
Loading tech rule set file : /software/designPackages/UMC_64bit/UMC180_Analog/Designkits/Cadence_6.1/RuleDecks/Assura/techRuleSets
Loading UMC_18_CMOS/loadCxt.ile ... done!
Loading context 'designrule' from library 'UMC_18_CMOS' ... done!
Loading context 'toolFunction' from library 'UMC_18_CMOS' ... done!
Loading context 'Callback_MM' from library 'UMC_18_CMOS' ... done!
Loading context 'Callback_RF' from library 'UMC_18_CMOS' ... done!
Loading context 'pcell' from library 'UMC_18_CMOS' ... done!
Loading context 'Util' from library 'UMC_18_CMOS' ... done!
Loading context 'update_pdps' from library 'UMC_18_CMOS' ... done!
Loading /software/designPackages/UMC_64bit/UMC180_Analog/Designkits/Cadence_6.1/UMC_18_CMOS/libInitCustomExit.il
*WARNING* (TECH-230035): User-defined rule "minExtensionDistance" in constraint
group "foundry" of techDB "UMC_18_CMOS" conflicts with
a built-in constraint with the same name.
You may write out "constraintGroups" section to an
ASCII file, reopen the technology database in "a"
mode, and reload the file to update the database.
Another option is to rename this rule.
*ERROR* No library model for device "RM1_MM".
*ERROR* No library model for device "RM2_MM".
*ERROR* No library model for device "RM3_MM".
*ERROR* No library model for device "RM4_MM".
*ERROR* No library model for device "RM5_MM".
*ERROR* No library model for device "RM6_MM".
ERROR: Assura is terminating because some library models do not exist.
Your rules and your dfII model libraries are inconsistent.
Assura requires all library models in the rule file be present
in the database when running rcx with the "extracted_view"
option.
INFO (LBRCXU-111): Warning /software/cadence/ASSURA/tools/assura/bin/rcxToDfII exit with bad status
INFO (LBRCXU-112): Warning Status 256
INFO (LBRCXU-113): Warning QRC execution terminated
***** aveng fork terminated abnormally *****
I am clueless about the reason behind this error. Please help me to resolve this issue as soon as possible.
