khanna_gunjan
Member level 3
- Joined
- Jul 18, 2006
- Messages
- 64
- Helped
- 9
- Reputation
- 18
- Reaction score
- 7
- Trophy points
- 1,288
- Location
- Nürnberg, Germany
- Activity points
- 1,699
qfn32
Hello All,
I am using a RF Chip with QFN 32 package. the problem is I have no idea how i can solder it properlz as the pins are all under the chip. I do have a Hot plate and the solder pump (but the noyyel is too BIg) but i don't have the stencil for this PCB, so when i applz the solder with this dispenser it is either too much or tooo less and the soldering is not proper.
As the PCB is still in the prototzpe stage i dont want to spend on getting it done from outside or buz a new hot air station.. which will be too expensive for me.
Please suggest the possible solution. Thanks in Advance.
Gunjan
Hello All,
Gunjan
