Q on csh script - setenv ROOT_PATH
no_mad
Full Member level 5
Full Member level 5
Naboo
Q on csh script
Here is my simple script:
#! /bin/csh -f
setenv ROOT_PATH `pwd`
Result:
It failed at setenv.
When I did echo $ROOT_PATH, it said ROOT_PATH: Undefined variable.
Please advice.
Thanks in advance.
Re: Q on csh script
in my c shell , it works , the echo result is "pwd"!
Re: Q on csh script
You could use "set ROOT_VAR=`pwd`" expression if you do not need to inherit $ROOT_VAR variable to child shell and deeper
Re: Q on csh script
Thanks for all the replies.
I have found the culprit.
It got nothing to do with setenv.
The problem is I'm trying to execute a tcsh file in csh.
Is it possible to do that? I'm just a beginner in c shell scripting.
#! /bin/csh -f
/proc/bin/setproj    #tcsh script file
cd my_proj
source $ROOT_PATH/my_tools/proj.env
Any ideas.
Thanks
Re: Q on csh script
Yes, sure you can run tcsh script in csh script. Just make sure "tcsh" script is "executable" OR you can use following statment to run "nonexecutable" script:
#! /bin/csh -f
tcsh /proc/bin/setproj #tcsh script file
cd my_proj
Re: Q on csh script
Hi kulyapinav,
Thanks for ur reply.
I tried and now it can execute.
But the problem is it dont proceed to the next statement in my csh file.
Until I type 'exit'.
After debug, i found out that the tcsh file checking for exit command.
Example:
if ($status == 0) then
                  do_this1
                  do_next
else
                  exit 1;
endif
Please help me out here.
Thanks
Re: Q on csh script
I am not able to reproduce the issue. Please, provide both scripts extended example
Re: Q on csh script
my main script:
#! /bin/csh -f
tcsh /proc/bin/setproj -p myproj -cfg U2 #tcsh script file
cd my_proj_path
here is the tcsh script called setproj:
#!/usr/bin/tcsh -f
      setenv MOUNTS /dir1/proj1
      setenv SETPROJ "$MOUNTS/proc/bin/setproj $argv"
      set cmd =  `$MOUNTS/proc/bin/setproj.pl $argv`
      if ( $status == 0 ) then
              eval "$cmd";
              set path = ($MOUNTS/proc/bin $path)
              source $MOUNTS/proc/bin/temp.csh
     else
              exit 1;
     endif
Re: Q on csh script
Your script looks fine and it works from my side.
Try paste here the error message that you see
Re: Q on csh script
Hi kulyapinav,
Thanks for ur fast response.
It is working.
There is no error has been generated.
The problem is after it executed setproj script, it didnt execute the next statement in main script. Until i typed exit.
main script:
#! /bin/csh -f
cd my_proj_path                                  #it will execute if I type 'exit'
Re: Q on csh script
I see. It looks like the perl script is waiting for some STD INPUT
Pay attention that you try to evaluate the perl script result. I suppose that process would like user to type something, to say another words it wait for response from input stream STDIN. Debug this part of code to be sure that nothing needed to suspend the execution on script.
To do more correct advice provide me "echo $cmd" result.
    no_mad
