J
Javid.zare.s
Hi, im gonna build a shoker with output of around 10kv or higher
I wanna use only a battery some safty switches and diodes and capacitors.i found this circuit online:
It shows for example at third step voltage will be 6x ,right?and i will not get even 100 volt maybe?(3.7 x 6 ~ 20 volts )
Can a 3.7 li-ion battery directly feed this or i need a choke to step up the voltage to 200 volts ?!?
