PWMWizard: tool for configuring PWM
SubhobrotoSinha
Newbie level 5
Newbie level 5
2006-10-10
Lately, I have been doing a lot of maths on my own because of my IR Obstacle detector design.
Noticed a lot of people asking for help on configuring PWM using CCS C.
Then it struck me.
Why not make a tool to simplify the process for all ?
So I sat down today, fired up my Visual C++ IDE and got may hands dirty.
The attached EXE is hot from the compiler, and with lots of "hidden features", of which even I may not be aware of.
Please use it a bit, and report the bugs.
Feedback, bug reports, suggestions, edge cases and tips on designing a small dual differential drive motor controller (preferably using a PIC) welcome.
Subhobroto Sinha
PS : The default values are for setting up the PWM for 38Khz, 50% duty cycle on a PIC16F877A @20Mhz
Just click on "Generate code" button to get ready code to copy paste in the CCS IDE
pwmwizard
Hi ,
Useful tool , good job !!
Can you write a version for standard register setup like this ?
PR2 = 00100000 ;
T2CON = 00000101 ;
CCPR1L = 00010000 ;
CCP1CON = 00011100
Or may be you like share source code , I can code in delphi and make modifications for write new application not for standard CCS C output .
I know is to hard to code from beginning. not like make modifications.
Another people write pwm wizard ,
see this link :
https://www.micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
this is write in Java
Regards
Garfield
pwm wizard
Thank you...
I had originally thought of including this very feature, but since it's not useful for CCS code, I left it out...
What you want will only be useful to a person coding in ASM (or are there some variants in PIC C which let you set these directly)...
However, if I see more interest in this, I will definitely incorporate MORE features...
What do you say ?
