[PIC] PWM USING PIC 16f887
incognito007
Newbie level 3
Newbie level 3
   Frequency 8Mhz
void main()
     PORTC=0;    //Clearing output port
     TRISC=0x00; //Initialising C port as output
     T2CON=0;    //Prescaler for timer (1:1) Timer2 off
     CCP1CON=12;  //Initialising ADC
     TMR2ON_BIT=1; // Turning On timer 2
      PR2=199;     //  Setting Time period/Frequency
     CCPR1L=80;  //  Setting Duty Cycle
Will this code generate 10 MHz
First thing your oscillator frequency is only 8 MHz, How can you generate 10 MHz
    V
Crystal Frequency 8Mhz
void main()
      while(1)
        CCPR1L=99;  //  Setting Duty Cycle
SORRY I want frequency of 10 KHz.This code is working in PROTEUS.
My question is ,when I remove the while loop and write CCPR1L=99; outside, the code is not working.
Why is it so
hello,
i didn't check your code, but you must have an infinite loop at the end of you code
else program stop..
void main()
         while(1);
Yes that for loop is loading the CCPR1L register infinitely.
Is it required to load the CCPR1L register with duty cycle bit every time a pulse is produced.
