vaka85
Hi all,
I'm trying to use pwm with the "bit banging" method. I know it's not very efficient, but it's a start..
The code below has a problem, and I'm not able to understand what it is...
I'd like to change the pwm value after some seconds, and so I start the pwm and after 5 seconds I call the function again, but with a different duty cycle value.
When I call the function "pwm start" without
it works fine.
But when I add the condition, pwm_start runs forever, without changing value and never ending, even if the IN4 goes off.
Could you give me any help? thank you
if(count<500000){
void pwm_start(long on, long off){
out3 = 1;
for (cntt=0; cntt< on;cntt++);
out3 = 0;
for (cntt=0; cntt< off;cntt++);
void main(void)
Ton = 2500; //2.5 ms
Toff = 2500; //2.5 ms
count=0;
while (1){
if( IN4 == 1) {
if(count<500000){
pwm_start(3800,1200);
count++;
} else {
pwm_start(4999,1);
} else {
count=0;
out3 = 0;
