E
eXnol
Hi everyone,
I am trying to 'DESIGN' an H-Bridge with PWM support. I have decided on the components to be 4xIRF540 as Motor driver, 4xTIP122 (or TIP127) as gate driver for the MOSFETs. The IRFs are used for the High side as well.
I have found out that the total time for the FETs to go from OFF to ON (full) is about 100nS and the total gate charge to be about 109nC. so I have decided to use about 1Amp gate drive current using the TIP.
I know the TIPS may be overkill but they seem to do the job and I have many available. I am planning to use a PWM freq of 200KHz (5uS) and the ON time being 100nS was wondering whether the TIP providing 1A at base bias of 5V and a gain of around 100-150 will be able to drive the FETs at 200KHz. The gain bandwidth product is around 250-300MHz and the switching diagram shows at 1Amp the TIP switiching time to be anywhere down till .05uS.
can I use the TIPs to drive MOSFET gates? Does my idea have any problems?
datasheet
TIP120 etc :http://www.onsemi.com/pub_link/Collateral/TIP120-D.PDF
IRF540 :http://www.irf.com/product-info/datasheets/data/irf540.pdf
datasheet
