Fávero Santos
Junior Member level 1
Hello, guys, how are you all?
I am currently trying to find a PWM controller to interface it to a Fixed Frequency Driver (FFD) from Brinrose - the FFD then drives an AO modulator (at 1550 nm). Such FFD has TTL inputs (0-5V) and 330 ohms impedance. The issue is that I am unable to find a PWM controller that can drive the TTL input of such FFD because we have a requirement of a minimum "ON time" of 10 ns (which may vary up to 500 ns in 10 ns steps) at operation frequency of 100 kHz. The PWMC ICs that I came across are mostly used for power management ICs (such as those used in switched DC-DC converters) and I am insecure if they are adequate for our application.
Could you guys provide me any hint or lead if there is any part or system that is able to drive this FFD? Could you guys provide me any other idea of how to proceed if no PWM controller with such requirement is available? (I am considering the usage of a microcontroller with GPIO drivers).
Many thanks, guys.
I really appreciate the time and effort you spent reading this request.
Fávero
Many thanks, guys.
Fávero
