labn1
Newbie
Hi ALL
I am a newbie to this tools. I runs virtuoso 6.17 which is pre installed in linux redhat 6. I run this to my laptop via virtual machine. I have collected this PVS[PVS15.20.000_lnx86.Base] files from the internet. I use this tools for learning purpose. I am also a new Linux user. The version of virtuoso which is installed contain calibre, when i tried to run LVS ,an error shwos up [the following products couldn't be licensed sufficiently - Calibre Interactive ] and i have tried to remove this error by editing the "license.dat ". but the error still presents. So definitely I need to find another way of verification. So I decide to setup the PVS menu , i read the instruction, although nothing is in there for that. I googled it , tried it to set up the "SETUP.SH" from the PVS folder applying via root user [i type "su -" in the terminal] . No error message showed up in the terminal. I thought it is installed properly and would be found on the layout window launch>plugins>PVS . but it isn't there. I also set done the patch in the same way i did for base file. The patch installation file is inside the PVS folder.
can any body help me out ? please ?
