mosfet123
Member level 2
is it possibility reduce PV panel area without changing the watt ? so 100W panel dimension is almost 790X670mm. is it reduce this dimension approx. %50 or what percentage can be reduce ?
That is a question that really only you can answer after you consider:
- what you want to the panel for
- how much you want to pay (more efficient panels are more expensive)
- what panels are available to you (locally, on-line etc.)
- do the available panels have the appropriate characteristics (you talk about the power but what about the voltage....)
- what other equipment is available to you (inverters etc.) that you might need for your particular purpose
We could recommend a high efficiency panel that is not available to you or is too expensive, so this is where you need to start doing your homework.
Susan
Which panels are more effective ? Do you know ?if you buy higher performing solar panels you can get the same 100W in full sunlight for very slightly reduced overall area.
Susan
