Alfred_zhang
Newbie level 6
improve timing fpga ise
Hi, thank u for your attention.
I am doing FPGA verification with ISE. The codes are fixed. signals in CDC file will be modified.
Sometimes when the signals in CDC are too many, then after PAR, there will be timing violations. By using timing analizer and FPGA editor, I can find the crital path and located it in the PAR's netlist. But that's all what I can do. To resolve the violation, I will try the whole process again: systhisize->translate->map->PAR. then I may get a good result if I have good luck. If violation again, try the whole process again.
Now u see it's very timing-wasted and a little fool.
U advice wil be appreciated! Or whan's your efficient methods to use FPGA editor and timing analizer?
Thank you!
Thank you!
