silver_sparrow
Member level 1
- Joined
- Jul 7, 2001
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- North Silicon Valley
- Activity points
- 231
Can someone tell if it is possible to distinguising the following two
black boxes:
Box 1 - From the interfacing box's terminnal a
1V ideal voltage source with a 1Ohm Resistor in series is connected.
Box 2 - From the interfacing box's terminal a 1V ideal current souce with a
parallel 1Ohm resistor is connected.
Both boxes are closed and you don't know which box is which. Using the
terminals to access the circuits inside can you determine which box is which
without damaging the circuits? You can us any measurment device or components
on the outside and apply it to the terminals.
PLZ- I don't want the answer, but would like to know if there is a soluition.
If the anser is 'yes' then is the solution complex or is it simple but tricky?
black boxes:
