cupoftea
Advanced Member level 6
Now i'm trying to do a dual opamp, MCP6002, one symbol including the power pins. Do you know how to do this?
I can do this easily in Eagle Pro. You just make two symbols separately in the lib...then shovel them both in when you make the "part".
...So now i have got the Part A and Part B in the lib...but it only places one of the parts on the schem sheet.
In the components window, it doesnt show the dual opamp as a 2 part device...but in the schem library, it shows as a 2 part device.
Ive just watched 2 altium videos on how to do this, and none showed how you get the components lib to show the 2 part device.
Even the Altium documentation doesnt show you how to do this....
...OK i deleted "U?" then re-typed it and now its ok......i presume i fixed this but it seems a bit bizarre
..I believe this needs registering as a bug in Altium...i just spent an hour trying to do a dual opamp multi part......it wouldnt work...then it did work when i delted the "U?" designator and then re-typed it , the exact same as it was before i deleted it.
Creating Multiple-Part Symbols for a PCB in Altium Designer
How to create multi-part components and symbols in Altium Designer®. Build a symbol manually or use an advanced symbol generator to do the heavy lifting of symbol creation for you.
resources.altium.com
How do I create a split component with shared pins between symbol parts on altium?
I'm trying to create a symbol for a dual op-amp on Altium designer, I want to have the symbols be the classic 5 pin representation of an op amp with both inputs, an output and the power pins. But w...
electronics.stackexchange.com
--- Updated ---
--- Updated ---
