T
treez
Hi
We are doing a 12kW output power supply with....
Vin = 700VDC
Cable resistance = 7.08 Ohms
Vout = 48VDC
Its an SMPS made with DCDC modules.
The load will have transients which are likely to be from no_load to 130% overload and vice versa.
Overload is treated with an output current clamp, but this takes some time to act (approx. 150ms).
In order to service these transients, (without the power supply tripping out) we are thinking of having a lithium battery simply connected to the output. (We need one there anyway to act as a power fail power source).
Is this concept of using a battery on a power supply output a common way of meeting heavy load transients as described?
There won’t be any interfacing circuitry (other than an initial inrush cct so that the battery doesn’t inrush to the power supply output caps upon connection) . The battery will start off being fully charged, so will only take a “trickle” charge from the power supply.
We are thinking of picking a ~47V battery so that it settles to 48V and just gets trickle charged as the power supply supplies the load.
Vin = 700VDC
Vout = 48VDC
