Tõnn
Hy!
I have circuit what I experiment in Pspice for my graduation work. This is 12V-24V DC converter with push-pull chip. I got with 24ohm load resistor exactly 24V, that means that I have 24W converter and that is what I want. But if I lower the load resistor the voltage going to rise. I can not getting work closed loop system what is controlled in error amplifier. I had turned off current sense because I do not know if I need that, and I do not know how to get it work. But the main problem is that I do not have closed loop system. I have connected the closed loop but in this way it does not work. I change a output voltage with voltage divider to the 5V and compared it with reference voltage which is also 5.1V and with that the output voltage must not be change. Pulse width must be change in the different voltage but it not. I do not know what I have to do with comp output, I find those capacitor and resistor values in the another schematic (I found that circuit in UC1846 Texas Instrument datasheet page with Pspice files). Xfromer is in 1:2 relationship. In the PWM chip datasheet there is not clear understanding what values I have to put. In my option, my circuit should work.
Any thoughts?
Sorry my English language, it is not good.
Any thoughts?
