which component are you talking about?
the resistor?
the push button?
the connector?
the connector looks like
Phoenix Contact COMBICON MC, 3.81mm Pitch, 3 Way, 1 Row, Right Angle PCB Terminal Block Header, 1803280
look in the con-phoenix-(size) library, where size is the correct pin spacing
Would be in xx381 not xx508 library. If this particular type isn't supported, use the next best 3.81 mm 3 pin connector.I do not find Phoenix Contact COMBICON MC in library I have downloaded
@ansh11
a toggle switch is not a push button
a toggle switch, in its simplest form, is an on off switch
the switch in your photograph is a momentary contact push button - likely close on push
the phoenix contact library is not listed that way - its listed as con-phoenix-(size)
were size is a three digit number, like 381, or 58 as FvM points out
The selected component has apparently 2.54 mm pin distance, indicated both by the name and the ruler. Having it in a xx381 library seems erroneous.Will this suitable?
