ansh11
Member level 4
I need to write code for following but I clearly don't have any idea so first I am trying to write pseudo code
When button pressed and released, Turn On led. When button pressed and released again, Turn Off led. Continue process
My work : I check button every 10 ms (timer interrupt) When I see a button change, I start counting interrupts. If the button is the same in the next interrupt, count will increment .
Otherwise, count will clear back to zero if the button has changed.
Once i reach a certain 10 counts. i can say that is a new stable state for the button, so I can say that as one press and turn on led
How to turn off led when second time button is pressed and released
