KrazyTurboTsi
Junior Member level 2
cd4028 schematic
I'm trying to build a push button shift box. In order to shift a gear, +12v has to be applied to two wires either one on, both on, both off or the other on. I would like to be able to make this work with push buttons. I was thinking i'd need to use relays to supply the power to the wires, but the problem I ran into is... How would I turn the 1st (1st gear circut) off, when I push the button to shift to 2nd gear? I would like to get away from the 3 position switch as it is WAY to easy to kick the car into a low gear by accident. My goal is to make a 4 button box to switch to the 4 gears.
3 position switch
TOP ON --- DPDT Relay --- yellow/orange +12 1st
Middle OFF --- yellow/orange off. 3nd
Bottom ON --- yellow +12 2rd
Toggle ON --- Orange +12
3 position switch
