Push button counter simulates but wont work on actual board Verilog
verilog_noob
I have a spartan6 FPGA board and am trying to have a pushbutton counter to a 7segment led. If I push button[0] I want counting up, and if I push button[1] I want counting down.
This all works perfectly in simulation, but not in actual on the board.
I know that my code for displaying the number on the 7-segment works perfectly, as it is recycled from a previous project. I know that I need a debouncer in the final version, but it should not matter, as it would just count by more than one.
I'm totally lost as to why this is not working, any direction would be appreciated.
here is the code.
MODULE: main
module main (button, userclock,sevenLed,cathode);
input  [1:0] button;
input [0:0] userclock;
output [6:0] sevenLed;
reg [6:0] sevenLed;
output [0:0] cathode;
reg [3:0] numSelect;
reg [3:0] out ;
reg [3:0] out2;
wire [3:0] wout;
wire [3:0] wout2;
clk_divider cd(userclock,cathode); //divides the clock
counter counter(button, wout, wout2); //does the counting
//always@(userclock) begin
//out=wout;
//out2=wout2;
//end
always @ (posedge userclock) begin
out<=wout;
out2<=wout2;
end
always @(userclock) begin //what side to show?
	if (cathode==0)
		numSelect=out;
	else
		numSelect=out2;
end
always @(posedge userclock)  //output to the 7segment display
    case (numSelect)
			0: sevenLed = 7'b0111111;
			1: sevenLed = 7'b0000110;
			2: sevenLed = 7'b1011011;
			3: sevenLed = 7'b1001111;
			4: sevenLed = 7'b1100110;
			5: sevenLed = 7'b1101101;
			6: sevenLed = 7'b1111101;
			7: sevenLed = 7'b0000111;
			8: sevenLed = 7'b1111111;
			9: sevenLed = 7'b1100111;
			10: sevenLed = 7'b1010101;
			default sevenLed=0;
    endcase
endmodule
MODULE: CLOCKDIVIDER (I know this works, as it was given to us, and used in previous projects)
`timescale 1ns / 1ps
//receives a 27 MHz clk on clk_27Mhz and generates a 1 Hz clk on clk_1hz
module clk_divider(clk_27Mhz, clk_1hz);
input clk_27Mhz; // user clock
output clk_1hz; // divided clock
reg [25:0] count; // counter, is bigger then we need in case you wanna play with it
reg clk_1hz; // don't forget the register
initial // This describes what to do as soon as machine turns on
begin
	clk_1hz<=0; // resetting everything
	count<=0;
end
always @(posedge clk_27Mhz) // whenever a rising edge of 27 MHz happens, do:
begin
	// This is just a counter:
	if (count >= 1350)
		count <= 0;
	else
		count <= count + 1;
	// counter ends here
	// this guy decides if it should be 0 or 1
	clk_1hz <= count >= (675) ? 1 : 0;
end
endmodule
MODULE COUNTER: (works in simulation)
// Company:
// Engineer:
// Create Date:    12:31:04 02/15/2011
// Design Name:
// Module Name:    counter
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module counter( clk_1Hz, num0, num1 );
input [1:0] clk_1Hz; // 1 Hz clock goes in here
output [3:0] num0; // this would show your ones
output [3:0] num1; // and this one would show your tens
reg [3:0] num0;
reg [3:0] num1;
//initialize the values (optional)
initial begin
num0 = 0;
num1 = 0;
end
always @ (posedge clk_1Hz[0], posedge clk_1Hz[1]) begin
if (clk_1Hz[0] ==1 && clk_1Hz[1]== 0)
	begin num0 = num0 + 1'b1; // increment the ones bit
		if ( num0 >= 10 )
		begin // if it is greater than 9
		num0 = 0; // reset it to 0
		num1 = num1 + 1'b1; // and increment the tens bit.
				if (num1 >= 10) begin // If tens is greater than 9
				num1 = 0; // reset it to 0
				end
		end
	end
if (clk_1Hz[1]==1 && clk_1Hz[0]==0 )
		begin
			if (num0 >=1)
			num0=num0-1'b1;
			else begin num0=9;
							if (num1>=1)
								num1=num1-1'b1;
							else
								num1 = 9;
					end
		end
end
endmodule
Hi
What is exactly not working? Leds always show zero, or they do not show anything, other errors?
It seems to just show random numbers. Sometimes a character will be the value for he defultv led case which should theoretically never occur. That case never occurs in the simulation
Where is clock signal?
There ia no clock passed to the counter. Again that was a recycled module. Button gets passed to that module which calls it clk1hz
may be the reason of failure in "There ia no clock passed to the counter". this is a good practice that counter has a clock signal.
How would I implement a clock signal to my current counter design?
it is better to use 27Mhz clock signal to your counters, and your clock divider should generate Clock Enable for counters. use language templates in ISE, they are really helpful
I am a bit confused still. The counter only counts wheen abutton is pushed. How do I go about using a clock signal for this?
this is only example, in this case you should push your button near 1 sec
Oh, this is an interesting question. Why don't you use assign in there? Open your Verilog book, it's explained there *trollface*
