Fearsome
Newbie level 6
I'm building a multi-message record/play unit based on a PIC, an ISD4002 record/playback device, an audio amplifier for the speaker, and a microphone. It's going to look something like the application example in the attached file (which is taken from the ISD4002 data sheet).
I've looked at the data sheet for the LM4860 amp and it's straightforward to connect. However, in the attached schematic there's a 1MOhm resistor (R2) between the audio out of the ISD4002 and ground. I can't figure out the purpose of this resistor. Does it have something to do with the line out jack? Any help is appreciated. It's probably very simple...
Fredrik
Fredrik
