pulsed, highly linear with diff bw required
jsp
Member level 3
Member level 3
hi all
i am searching the design for the following
20MHz - 100MHz - 400W
100MHz - 300MHz - 400W
300MHz - 600MHz - 60W
if any ref or any book is there pl suggest.
thanks in advance.
jsp again
if somebody is having idea about it pl reply
thanks in advance
buy or just want to the reference,and the detailed requirement
This is a difficult design problem. For such a wide frequency range there are usually two amplifiers for sub ranges and combiners. But with your high power requirements the combiner losses would require 1 kW or so for each amplifier and a lot of heat removal fins.
If this is part of a larger system you could use switches to route the signal and load to the appropriate amplifier. That is if the frequency of your signal does not hop rapidly over the whole bandwidth.
