cupoftea
Advanced Member level 6
Hi
Do you know what is the pulse rating of the resistor SMQW322RJT? (13.5 x 7.3 x 6.8mm)
SMQW322RJT
Can it handle the attached power pulse? (this is what it would see)
As a way of comparison the SG73 (size 2512 = 6.3x3.1mm) resistor can do 110W for 20ms...
...so, the SMQW322RJT, being much bigger, and wirewound, you would think it would be good for at least double that?
For more comparison, the AC03 (13x4.8mm) resistor is about the same size, and can do 200W for 20ms
Even the small MMB0207 (5.5x2.2mm) can do 15W for 20ms
..So surely the SMQW322RJT could do the shown ~30W for 20ms?
And as you know, we can always do a test jig which gives it the inrush once every 30 seconds, and leave it on for a week, that should be a good test...but probz not allowable due to fire regs.
SMQW322RJT
