pulse output circuit in energy meter
it is called "S0" interface.
Here you can connect other external metering devices.
The simplest is a mechanical pulse counter. It shows the ammount of energy.
Klaus
thanks Klaus. I have some more doubts.
1. So if I ignore this circuit,will it affect other circuit?
2. Should I add any circuit for finding active and reactive power? or is it internal calculation by microcontroller?
If you don't need the pulses, leave it unconne ted.
There is a metering chip inside, it calculates reactive power.
Klaus
