T
treez
Hello.
I have a switch which pulls down (to ground) a pin of a PIC18F65K22 Micro to give a logic low.
If the switch is open then the pin is pulled up to the 5V rail via a 47K resistor.
Do you think I need a 10n (or thereabouts) capacitor connected to the pin to reduce noise at the pin?
When pulled high, and without such a capacitor, do you think that the logic high will be too noisy...and will sometimes be taken as a low due to noise?
