hithesh123
Full Member level 6
If an IC has Enable/disable pin, is a pull up/down resistor really required?
How is the exact value calculated?
You have to be more specific, in which device are you referring?
The disable pin usually leaves the pin floating, if you want to force a value then use a pull up/down resistor, 10K-47K should be fine
Alex
