baby_1
Advanced Member level 1
Hello
Im starting to work with PT100 temp sensor.i series a 100ohm resistor to it and wants to find the voltage across from the 100ohm resistor that should change with temp.but as i tested it by PIC18f4550 ADC (10bit adc) it doesn't work properly (doesn't change voltage) and the output of adc was fixed to (471-467) i wonder why it doesn't work while when i tested the PT100 with ohm meter and find that it resistor change via each centigrade (.4 ohm resistor increase when 1centigrade temp increase)
now i want to use ad7730 to sensing the PT100 , what is best circuit via PT100 and AD7730?
Thanks
Thanks
