gauravkothari23
Advanced Member level 2
Hi all.
i have made a circuit to interface PT100 with my microcontroller Nuvoton N78E517A.
Circuit diagram attached of Amplifier, my issue is with the software part.
ADC Used is MCP3202 and amplifier used is LMV358.
what my problem is how should i calibrate the PT100 sensor. for example, at 100 Ohms the temperature is 0 Degree. so to calibrate it i added a 100 ohms resistor at input and whatever value i get at ADC, i calibrated to 0 degree. but what the problem is when the resistance rises, say like if i add a 220 ohms or resistor , the voltage at ADC too rises, and the value temperature what i get is something different that the PT100 Chart.
i am bit confused about the logic, how should i calibrate the PT100 to get appropriate reading.
